I have a question regarding onboard graphics. Is is possible to run the onboard graphics with a separate GPU?
I have a few spear monitors laying around and because I am already using two screens on the GPU, I wanted to know if I can use the onboard controller as well.
Are you asking if you can get the display from the motherboard and use both display ports on the GPU. You might if you give it a try. But I dont think so, maybe you can... give it a try.
Depending on what you have you can crossfire, but you could also simply use one of those DVI->VGAx2 splitters, don't know if they work though,or you can use the DP output from your GPU.
