Introduction:
So... I ordered an XFX Pro 550W power supply and, after putting together my friend's rig, I realised there was a pretty big problem with a power supply (well not the power supply really but idk bare with me). So, after building, I realised that the cable that connects the power supply to the wall plug-thing is SPANISH. I bought UK store where nobody else had this problem. Great. Thanks XFX. I can't return the power supply in time from christmas.
TL;DR: Spanish cable on a UK power supply, can't return in time for xmas.
My question: Can I use a cable thingy from another power supply, that's 550w and the same amps but I'm clueless when it comes to compatibility. Does the cable matter? Does it have to be a specific one? Should I just use a Spain-UK socket converter thing (I go on holiday to spain every year so I have more than enough)? Is that safe? I'm really confused. Will not be buying anything from XFX again, screw good capacitors, they're terrible for misleading me.
Bought the psu from: http://www.cclonline.com/product/62301/P1-550S-XXB9/Power-Supplies/XFX-Pro-550W-Power-Supply-Unit/PSU0246/?siteID=8BacdVP0GFs-gPknO280v2kPTrrNHzyRiw
I'm really confused and need help before tomorrow or I've ruined Christmas (for the second time with this PC).
