Hi
I recently overclocked my i7 2600k to 4.4ghz and I choose to set the voltage using offset instead of just a constant manual voltage. However under full load cpu-z reads 1.272-1.288V but when it's not under 100% load ie just browsing the web I've seen the voltage go as high as 1.34V, though it only goes high for a short time it is usually around 1-1.2V? So what I'm wondering are these voltage spikes normal and safe? BIOS settings that I set, load line calibration = regular, Phase Control = Optimized, CPU voltage = offset mode +0.010V.
Cheers.
System specs
Intel Core i7 2600K
Coolermaster hyper 212 EVO
ASUS P8P67 Deluxe
HIS HD6970
8gb G.Skill ripjaws CL9 @ 1600mhz
Enermax NAXN 850W
Cosair Force 3 120gb SSD
Western Digital 2tb Cavair Black
Antec 902 V3 Case
