[Official] L1Techs Products Hotkey Lists
This is just product information & technical data. For any further information, clarification, or explanation, please reference our very detailed FAQ that’s always being updated & checked!
If you have a question about a product you may leave a post in the → KVM Helpdesk area, I’ll get back to you asap.
Catalog of items in this post:
General Hotkeys
A hotkey command is a short keyboard sequence for selecting a computer, activating computer scan, etc. The KVM interprets keystrokes for hotkeys all the time. A hotkey sequence starts with a Hotkey Leading Code followed by one or two more keystrokes. After the Hotkey Leading Code is detected, the KVM will interpret keyboard commands until the end of the command.
Note 1: For hotkeys a USB-HID compatible keyboard/device must be connected to the white USB-HID ports.
Note 2: Gaming peripherals or other devices may not work in USB-HID, if so just plug it into one of the blue USB 3.2 Gen 1 ports.
Note 3: Don’t use the Num pad on the right side of your keyboard, use the top row instead.
Possible Hotkey Leading Codes:
  • L-Ctrl
  • R-Ctrl
  • Scroll Lock
Port Selection
Key Sequence Function
Hotkey Leading Code + 1 ~ 4 PC Port Selection 1 ~ 4
Hotkey Leading Code + 0 Return To Last Selected Computer
Hotkey Leading Code + F1 Auto-Scan Ports
Hotkey Leading Code + F2 Manually-Scan Ports: Allows users to manually switch back anbd forth between power-on computers. Press the :arrow_up_small: or :arrow_down_small: key to select the previous or nect computer.
Hotkey Leading Code + F3 Adjust Scan Rate: The KVM switch generates 1 to 4 beeps indicating the duration of scan time (3, 8, 15, and 30 seconds respectively.)
Audio
Hotkey Leading Code + F5 Audio Follow Port Selection (ON / OFF)*
Hotkey Leading Code + A Force Audio Follow to Current Port
USB
Hotkey Leading Code + F7 USB 3.2 Gen 1 Follow Port Selection (ON / OFF)*
Hotkey Leading Code + U Force USB 3.2 Gen 1 Follow to Current Port
Operation
Hotkey Leading Code + Alt (hold) + G Disable/Enable KVM Beeping Sound
L-Shift (hold) + Num Lock + Num Lock + (release L-Shift) Enable Num Lock as a Hotkey Leading Code
L-Ctrl + L-Ctrl + Alt (hold) + R-Ctrl + (release) Alt Change Hotkey Leading Code from L-Ctrl to R-Ctrl
R-Ctrl + R-Ctrl + Alt (hold) + L-Ctrl + (release) Alt Change Hotkey Leading Code Back from R-Ctrl to L-Ctrl
*The default audio & USB 3.2 port follow status in on, and follows port switching. The user may turn this off so that their USBs stay at their original port.
KM Hotkeys
Mouse Speed Management
Set mouse DPI (UP Arrow Key) Hotkey Leading Code + L-Alt (hold) :arrow_up_small: 1 Beep = -100 DPI (Speed Up)
2 Beeps = Lowest DPI
Set mouse DPI (DOWN Arrow Key) Hotkey Leading Code + L-Alt (hold) :arrow_down_small: 1 Beep = +100 DPI (Speed Down)
2 Beeps = Highest DPI
Mouse DPI Quick Configuration L-Alt (hold) + S 1 Beep = “Low” Preset (2400 DPI)
2 Beeps = “Mid” Preset (600 DPI)
3 Beeps = “High” Preset (200 DPI)
Mouse DPI Manual Configuration L-Alt (hold) + “xx” Examples:
“01” DPI = 100 (Highest Speed)
“02” DPI = 200
“20” DPI = 2000
“24” DPI = 2400
“48” DPI = 4800 (Slowest Speed)
Mouse Roaming
Hotkey Leading Code + L-Alt (hold) + Q + “1~4” Monitor Configurations *see below
Hotkey Leading Code + L-Alt (hold) + Q + 0 Disable mouse roaming
Hotkey Leading Code + L-Alt (hold) + R 1 Beep = Borderless Circulation ON
2 Beeps = Borderless Circulation OFF
Original KMs Only
Model#s ending in: 304 & 314
Ctrl + Ctrl + Alt (hold) + Q + X + 1 The preset used will depend on your USB ports:
Use ports 1/2/3 to enable 1 - 2 mode. Use ports 2/3/4 to enable 2 - 1 mode.
Special Monitor Configurations
USB Audio KM Only
Model# ending in: 314
Audio
Ctrl + Ctrl + Alt (Hold) + A + 0 Disable USB Audio
Ctrl + Ctrl + Alt (Hold) + A + 1 Enable USB Microphone-In
Ctrl + Ctrl + Alt (Hold) + A + 2 Enable BOTH USB Audio Line-Out & Microphone-In
SYNC KM Only
Model# ending in: N334
Serial Commands
Serial Command Function
K= 1~4 ( + Enter) Select KM (Console) Port 1~4
K < ( + Enter) Select KM (Console) Previous Active PC Port
K > ( + Enter) Select KM (Console) Next Active PC Port
U = 1 ~ 4 ( + Enter) Select USB 3.2 Ports = Port 1~4 (Stop Following)
U = * ( + Enter) USB 3.2 Ports Follow KM (Console) Selection *Default
U + $ ( + Enter) USB 3.2 Ports Stay at Current Port (Stop Following)
A = 1~4 ( + Enter) Select Audio Port 1~4 (Stop Following)
A = * ( + Enter) Audio Follow KM (Console) Selection *Default
A = $ ( + Enter) Audio Stays at Current Port (Stop Following)
N = 1~4 ( + Enter) Select LAN Port 1~4 (Stop Following)
N = * ( + Enter) Net Follow KM (Console) Selection *Default
N = $ ( + Enter) Net Stays at Current Port (Stop Following)
H = R ( + Enter) Restart the KM Switch
B = 1~4 Equal to Pressing Front KM Button 1~4
B = S / A / N / U Equal to Pressing: SYNC Button (S), Audio Button (A), NET Button (N), or USB 3.2 Button (U)
B = a1 / a2 / a3 / a4 Equal to Pressing: Audio Button (hold) + PC 1~4 + SYNC Button
B = n1 / n2 / n3 / n4 Equal to Pressing: Net Button (hold) + PC 1~4 + SYNC Button
B = u1 / u2 / u3 / u4 Equal to Pressing: USB 3.2 Button (hold) + PC 1~4 + SYNC Button
B = sA / sU Equal to: Pressing: SYNC Button (hold) + Audio Button / UBS 3.2 Button
B = sN1~4 Equal to Pressing: SYNC Button (hold) + NET Button + PC 1~4
Adjust Baud Rate of The KM’s Serial Port
There are 8 bands of baud rates available (9600 ~ 115200).
“Bp3” = The 3rd K/M Button on the front, next to the number 3.
Baud Rate Band Key Sequence Set Rate
1a Hotkey Leading Code + L-Alt (hold) + “Bp3” + A + 1 Baud Rate = 9600bps
1b Hotkey Leading Code + L-Alt (hold) + “Bp3” + B + 1 Baud Rate = 14400bps
2a Hotkey Leading Code + L-Alt (hold) + “Bp3” + A + 2 Baud Rate = 19200bps
2b Hotkey Leading Code + L-Alt (hold) + “Bp3” + B + 2 Baud Rate = 28800bps
3a Hotkey Leading Code + L-Alt (hold) + “Bp3” + A + 3 Baud Rate = 38400bps
3b Hotkey Leading Code + L-Alt (hold) + “Bp3” + B + 3 Baud Rate = 57600bps
4a Hotkey Leading Code + L-Alt (hold) + “Bp3” + A + 4 Baud Rate = 76800bps
4b Hotkey Leading Code + L-Alt (hold) + “Bp3” + B + 4 Baud Rate = 115200bps
Controlling Another Serial Device via Hotkey Commands
  1. Ensure baud rate is the same.
  2. Connect a serial device to the serial port.
  3. Adjust the baud rate based on the connected device (if necessary)
  4. Use the console’s USB keyboard to enter**:
    L-Ctrl + L-Ctrl + L-Win (hold) + L-Shift (hold)
  5. Enter the serial command with the console’s keyboard (keep holding buttons)
  6. Release the buttons after finishing the serial commands
** Release L-Shift if lower-case or special symbols are required.
LAN
Hotkey Leading Code + F8 NET Follow KM (Console) OFF/ON
Hotkey Leading Code + N Force NET Follow to Current Computer
Hotkey Leading Code + L-Alt (hold) + F + A + C Return to Factory Default
Mouse Roaming
Hotkey Leading Code + L-Alt (hold) + Q + L + “1~4” Monitor Configurations *see below
Hotkey Leading Code + L-Alt (hold) + Q + M + “1~4” Monitor Configurations *see below
Mouse Control
*You will need a mouse with at least a 4th customizable button to act as your hotkey. (the standard being left (1), middle (2), and, right (3) buttons).
Mouse hotkey leading code = “Bm4”
Hotkey Leading Code + L-Alt (hold) + Bm4* Enable mouse control and assign a mouse leading hotkey code
Bm4 (hold) + Middle mouse wheel (scroll up) Select previous PC channel
Bm4 (hold) + Middle mouse wheel (scroll down) Select next PC channel
L-Alt (hold) + Left mouse button Disable mouse control
Advanced Monitor Configurations
More to be converted & added soon!
Coming up:
  • Combo KVMs
  • Roaming Mouse KMs
  • Ethernet Extender
  • USB-C Combiner
  • Repeater/Splitter
  • HDMI KVMs
Feedback welcome :slight_smile:
Added hotkeys for KMs.
Adding the “Function Modes” reference table since I keep forgetting how to toggle USB Sync on the v2 KM:
Function mode 1st step 2nd step 3rd step
Panel lock Func (Bf) Audio (Ba) ø
Hard hotkey Func (Bf) USB (Bu) ø
Roaming Func (Bf) NET (Bn) K/M 1 (Bp1)
Mouse control Func (Bf) NET (Bn) K/M 2 (Bp2)
Hotkey control Func (Bf) NET (Bn) K/M 3 (Bp3)
USB Sync Func (Bf) NET (Bn) K/M 4 (Bp4)
Hello i bought this version: " 1.4 Display Port KVM Switch - Dual Monitor - Two Computer" (cant post links, or else i would, sorry) around 12/9/2023 as the 10Gbit version. Im playing right now Enshrouded as a game and im using a lot of Bar-Switching which is Left CTRL in the game. Took me a bit of time to figure out why my screen without sound blanked out to black and pc wasnt responsive anymore. When i finally figured out i switched to input 2 i was very confused, because i thought this would only reacht to SCROLL, SCROLL, 1/2 Keypress.
After trying to remap the Left CTRL to Right CTRL as you wrote in the upper posts i get a Sound, but im not sure if that is an error or confirmation sound, its just a beep. Also it still sticks to Left CTRL, i cant change it to Right, could you guys please help me out? Im very confused and a bit angry from dying all the time ingame :sweat_smile: - Please Heeeelp :grin:
@wendell @Level1_Amber please help :sob:
just use scroll lock double tap scroll lock then hit left Ctrl. itll disable Ctrl S a leading key and you can use scroll lock instead
Big thanks, that worked!
Hi how can I change the hotkey to switch from anything except control because none of the other options are working
