Good Afternoon All!
I have a t460p Thinkpad that I use for work, a problem suddenly started happening when I use the keyboard. The “A” key is super sensitive. You don’t have to actuation the key switch the slighted brush over the “A” results in a string of “A’s” I pulled the keycap and made sure the switch was clear of crude/trash. With the key cap removed it had the same problem, you just barely make contact with the top of the rubber dome and you get a string of “A’s”
I like to repair my own gear when possible so I will order a new KB if needed. Just curious if anyone has run into this before and is the switch fixable?
Thanks!
