Oculink to sata?
I built finally the TrueNAS with epyc a bit powerfull one than I thought due to the shortage… and Now I came with some doubts.
The Motherboard ROMED8-2T comes with 2 SAS connectors that I’m using for SATA 3 SSD.
But I still need some more… the motherboard has 2 Oculink, and I shifted the jumpers for they to become active, but seems like the Oculink to 4xSATA3 cables I got are useless because the motherboard won’t detect anything I plug there…
anyone has experience with this?
even if there is enough banwith won’t work because other reasons?
if I don’t use that oculink then what PCIe SATA expansion would you recomend? I was planing to do software raid anyways.
Thankyou!!!
I haven’t tried an oculink, but bandwidth should not stop it working.
Unless you are already using all the pcie lanes in the pcie sockets.
I would guess either a bad cable, or bad socket setup.
You had to change jumpers, perhaps there is a bios setting to switch socket modes?
As for sata expander, I would personally suggest a uses SAS controller, which you can get “forward breakout cables” for (sff 8087 to sata)
Like this, but others available
You could buy SATA cards, for less, but they seldom have as many ports, and even used server gear might be more reliable than even new hitech cards.
Mostly, I would double check why the board is not working with the occulink sockets, maybe even email the manufacturer/distributor, in case it might be a hardware defect?
I have never used it, so not sure
Thank you for your reply.
I think I setup the jumpers in the correct way. ( both in the 2-3 ) I will double check.
PCIE 2 should be totally disabled following the Motherboard instructions.
The bios options is hge on that motherboard and half of it is hard to understand… I guess I need to investigate a bit more. mini SAS was so easy… plug & play…
I’ll give another try and possibly purchase another cable just in case.
I also contacted Asrock for that matter I guess I’ll get reply on Monday.
And If finally can’t make it work I like the idea of using SAS connectors! thank you!.
well didn’t get the Asrock confirmation yet, but found another post where it was saying that he asked and the problem was that the Oculink in the motherboard can’t accept SATA. so I guess I need to purchase a SAS pcie.
Thank you.
Thanks for getting back to us.
I had high hopes when I say these Occulink sockets arriving, but it seems they aren’t worth much, unless one has a U.2 drive? and they are pretty dear in price, for what you get.
Had the same problem with the Board. Tried to use the Oculink with an ICyDock chassis (MB516SP-B) and it did not work with any cable. Was Oculink to miniSASHD. I tried the cables MiniSAS HD Cable CBL-SAST-0929 / 0972. Finally gave up and bought an additional HBA (Microsemi Adaptec HBA 1100 16i ) which is pretty nice and can easily be cooled. My Board came btw with an Oculink to 4x Sata cable which worked.
