Oculink (SFF-8612) to m.2 woes
I have been wanting to use the oculink connectors on a ASUS krpa-u16 and i bought this https://vi.aliexpress.com/item/1005005287747558.html#nav-review
thing is it does not work and a review said it needed 3.3 which i soldered (used the sata power cable 3.3 line and ground). this makes the nvme do … something as it heats up its controller. how ever no detection.
the nvme works if i just insert it in a normal m.2 slot.
sad part is i designed / printed a holder for multiple of these cards which i have bought :frowning:
