Hi,
As you can see on my profile, I have an Asus Sabertooth 990FX R2.0 with an AMD FX-6100. Since I wasn't entirely happy with my speed, I decided to do some overclocking. I got some tips from ex-classmates to start by increasing the CPU multiplier, so I increased it in little steps from 16.5 (which is stock) and I stopped at 22.5.
My CPU is now running 6 cores at 4.51 GHz and not even touching 70°C when running prime95 overnight (with stock voltages and no errors whatsoever). Because I got it so easily to such a boost, I'm starting to think I may be missing something or doing something wrong.
Then, I did some research and found this comment:
Wish you luck, FX-6100 is by far the hardest CPU to oc that I've ever owned.
Now I have to say I use a closed-loop watercooling solution, which may explain some of the ease, but I still think I am missing something.
Any thoughts, anyone?
- Robin
