So I am planning on oc'ing my CPU, the reason being I'm gonna buy the Noctua NH-D14 in a month or so depending when I have the money. http://pcpartpicker.com/p/1Diun this is my build as it stands. So as you can see I have an FX6300, and at the moment with the stock cooler it's running at ~3,8 ghz, and it doesn't go over 50C when gaming.
So I have a couple of questions regarding oc'ing it when I get the new cooler. So first off can my PSU and motherboard handle a decent oc? I have oc'ed my GPU already so it's core clock is 1000mhz and the memory clock is 1395mhz at stock voltage. So will the motherboard and PSU handle a oc, or will I have to upgrade that aswell?. another question I have is about the oc itself, I want to know how to oc it basically, like how to do it, through the bios? and how much should i increase the speed at the time, and like when it comes to voltage I also need some help, so a guide for how to oc would be good, I just don't want to break anything since this will be my first real oc. And are there any good free programs I can use to test the stability? if so what do you reccomend?
You won't be able to utilize a NH-D14 to it's full potential due to your low end motherboard. A NH u-12 or a Xigmatek Dark knight might be more appropriate. As for how to overclock, here are the basic steps.
Step 1: Download prime95 and a program to monitor your temps like coretemp.
Step 2: boot into your bios and raise your core multiplier until your clockspeed is about 200mhz faster.
Step 3: boot into your OS and run prime 95. if you don't get any errors or crashes, go back into the bios and raise the multiplier some more.
Step 4: When you eventually get an error or crash while running prime95, go into your bios and raise the voltage slightly. Run prime95 again, this time monitoring your temps. Make sure your temps are under the max safe temp for your CPU. (about 65 degrees)
If you continue to get crashes, and your CPU is not nearing 65, go back to the bios and raise your voltage some more. If your temps are acceptable and you are not crashing, repeat steps 2-4. When you near your max safe temp you are done. If you are getting errors no matter what you do, go back into your bios and lower your multiplier until you are no longer getting errors.
Okey thanks, for the detailed reply it really answered all my questions except if my PSU can handle the oc, and I would rather get a new motherboard, than buy a different CPU cooler, what AM3+ motherboard would you recommend?
Keep an eye on your Power Suply too, it's only 500 watts, and most of thepower supplies really hold 450/470W : When they deliver the " Max " Wattage that they can deliver, they are at 100%, wich kills them really fast (question of minutes)
