I was wondering if anyone has run across stable low temp settings for an 8150 on a sabertooth 990fx in a 4.4 to 4.6 range. I know every chip is different and it may not be as easy as just mirroring settings but I'm not really happy with my temps on my OC. I am curious to know if anyone uses or has seen this same setup with a low temp stable overclock.
Well I had an overclock of 4.6GHz on the 8150, but I have watercooling and that was about the only way I was able to go that high.
Whats your current clock and CPU cooler?
- zanginator
highest stable clock is 4.5 with an h100 but my board temps were hitting 65c and cpuid hw monitor had the actual chip around 60c thats after about 30 mins of prime95
I would not go any higher then. Play it safe and don't push it any further or you may burn the board or the chip out.
ya thats why I was wondering if someone had different settings with lower temps I'm not really satisfied with those temps they seem a bit high even for a closed loop cooler.
They need to hurry up and release the Corsair Obsidian 900D I've decided that will be the base for my custom loop setup.
