Occasional GPU Freezes and Errors
I have a Dell Inspiron 530s running 6GB of Pc2 6400 memory and I'm planning to replace the 2x1GB sticks with 2x2GB.  The processor is an Intel Core 2 Duo E7400.  The mobo has a G33 chipset, I think.  I decided I'd upgrade it into a moderate gaming machine by adding a respectable GPU, so I bought a Sapphire Radeon HD 7770 the day after Christmas.  It runs well most of the time.  Sometimes, it hangs-up.  Every once in a while, even when not in a game, I will see flaws with the bottom 1/3 of the screen.  Sometimes when the desktop loads, the bottom 1/3 of the screen is black for less than a second and then it displays the rest of the screen.  Sometimes in a game, like Oblivion, the card behaves like the bottom of the screen is having a hard time keeping up.  Tonight, when playing Oblivion, the screen turned into grey and white vertical lines and I had to hard-reset to get back to the desktop.
I am not aware of this card running hot.  I watch all my systems' temps all the time and shut them down if they seem to be getting hot.  This machine never reaches 50C.  Even in-game, it runs pretty cool.
check if your power supply has the manufacturer recommended wattage, if it was just an apu machine before then it could be drawing too much power.
I bought a WT620Q (620W) PSU when I bought the graphics card.  The minimum requirement is 480W.  The original PSU for this Dell was 300W, which is not as shabby as I would have expected for a factory PSU, but not as beefy as most modern GPU's demand.
I am not familiar with WT, but a personal friend of mine, who is a computer tech suggested it as a less-costly power supply that would still meet my needs.
I'm thinking about replacing the WT with an Ultra  600W.  I like Ultra power supplies.
Have you installed the ATi drivers?
I downloaded and installed new drivers from AMD.  The problem persists, in Oblivion, but Skyrim runs flawlessly, at "Ultra" settings.  What's up with that?  I run Skyrim around 60FPS, but Oblivion has always run 10-15FPS lower.  Now, I can't run it at all.  I guess I'll just bust out the Athlon 64 (single-core) with the GeForce 9800GT and play on that.  It runs Oblivion without any problem.
