OBS or XSplit Gamecaster
Okay so I have decided I want to start streaming to twitch, and was wondering what I should be using, I have had few issues with OBS, mainly stuttering on the playback when it shouldn't be doing so as I have very high bandwidth and I am playing at 720p 30FPS.
Anyways should I pay the $15 every 3 months, or stick with OBS and seek out help with my issues.
Thanks
Having using both I can say this
Xsplit-extremely easy to use and customize. paying the 15 is worth it imho
only problem I ran into with xsplit is that it doesn't play nicely with ENB mods(skyrim for example)
Had to download OBS to stream my modded Skyrim
OBS is a little difficult to set up your scenes but once you're set its easy to click and go.
OBS all the way. Supports Shadowplay and it is basically the only good free stream AND recording software out there right now. FFSplit is garbage but I have it as a just in case.
