NZXT Source 340 case painting
Picked one up as my other mid tower was not setup as well for cable management. Painted it before installing hardware. Here is what it looks like all done. All red parts I painted, including the front of the case.
That looks awesome, wicked job! how easy was it to paint and build in this case? I'm considering getting it
What paint did you use? I did something similar to my H440 and the paint I chose drove me mad, great now that it is done though.
The case is quite easy to work with. The only problem I had was with sorting cables from the PSU. It can get a little cramped if you have a bunch of cables in the bottom. The paint I used was Krylon Fusion - 2328 Red Pepper/ Safety Red. I had a different project I was working on and used the 3/4 of a can I had left to paint the SSD brackets, cable bracket, and front panel of the case. Each has about 3 coats.
