NOTE: Yes its easier to buy a new case, BUT I DONT DO SHIT THE EASY WAY!
I do it the fun way
So the first time I put my, at the time, $25 case to the grinder was here. Now after having been on FX for a while I've noticed my 8320 runs in the 70's in GTA V (not good). Clearly my h80i paired with the lowest speed EK Vardar wasn't cutting it. My solution is simple. I need a dual rad cooler. The problem is the 210 barely supports a single rad with no hope for a dual rad. Which brings me to point of this post. I'm going to MAKE my case support my brand new H105. Logan always says in a case review "I wonder what the modding community will do with (insert case here)". I'm here to chip in
also my straw poll told me to http://strawpoll.me/4493275/r
p.s. My RM450 is getting swapped out for a brand new HX750i as well because the blue accent matches better with my color scheme. Gold and blue don't mix unless your a U of M Wolverines fan.
more posts to follow
