Hi I am building a new Gaming PC, and the case I have chosen is the NZXT source 210. I need to know if my graphics card will fit in the case with everything else installed. This is my graphics card. http://www.amazon.com/dp/B00FONITA6/?tag=pcpapi-20
And this is my whole build in case you wanted to know.
http://pcpartpicker.com/p/1Xll8
So is my graphics card, mobo, or PSU to big to fit I'm the case without moving any of the HDD and optical drive cages or anything that was preinstalled? Thanks
Sadly no, the card is 15.9 inches according to overclocker.net and amazon. This when converted to millimeters is 403.86 which exceeds the 330 millimeters the case allows even with the hard drive cage removed. The wind force cards are huge though you should be able to get an R9 280X without trouble. The XFX double D would fit. I am sure there are more but that is the only one I looked at.
It will fit because you can fit cards up to 330mm long but this card is only 285mm long. I have the same case and it fits cards bigger than that.
Fair though the calculator must have messed up. Listen to the guy who has that card!
