Will it fit this http://www.nzxt.com/new/products/cpu_cooler/havik_140 on this http://www.techpowerup.com/reviews/ASUS/Maximus_V_Formula-ThunderFX/ with standard height ram in the NZXT Phantom? http://www.nzxt.com/new/products/crafted_series/phantom
Yup. Shouldn't have any issues.
Thanks for the reply. I was thinking of using the NZXT switch 810 instead which should still fit, correct?
The Switch is larger than the Phantom. It should fit without issue.
Ok thanks for the help man
