so as u know i have the nzxt phantom and have some questions about the case fans.
my pc specs:
Nzxt phantom full tower
asus z77 maximus v formual
i7 2600k
16gb ram
Evga gtx 670 ftw
1) I wanted to know the actual speed of the 120mm fans?
Now my temp for gpu while i was gaming was 70 celcius max and i want to know if thats good or not. I would also like ur opinion on my decision on changing the case fans to better ones. If yes can u tell me of some good fans 120mm and 1 140mm for the front. And if u think i should not change my fans can u explain y?
Thank you =D
