I've had this case for a while; its time to do something about that. This will definitely Take a long time and I have no means of acquiring any of this yet. I'm prepared to save up for the next few months.
Just be sure you dont get a long modular psu as you wont be able to clear the 280 in the bottom. Even a 240 in the bottom doesnt leave all that much room for cables. 2nd res = waste of money.
Indeed, I've already checked the clearance and it should be good to go👍 I had a dream once that my computer was already watercooled and had like pluming hose instead of tubes like this I'm actually curious if something like this would even work
You have to compensate somehow. or you will have negative pressure in the system. 4 exhausts vs 3 intakes does not work well unless those 3 intakes are spinning faster
It depends on the metals used in pluming hoses , there is a chance of galvanic corrosion depending on the rest of metals used in your loop. If you decide to use second res make sure it doesn`t make your loop more difficult to bleed , add extra flow restrictions or extra bubbles.
