I've been looking at the Cooler Master TPC 812 with 2 sp120 fans on it but is quite expensive and would like to know if the Havok will fit in my case cause from what I've heard and seen the havok looks like a really good buy. If you think i should stick with my first option please say so, but if they are relatively the same performance then i'd probably go for the Havok if it fits.
Thanks,
Jamie
