As the title says will this CPU cooler fit with the side panel on? If not can you recommend another CPU cooler at a similar price?
P.S. I know Noctua are good but I hate their colour scheme and I'm trying to colour code my build with red, black and white so yeah...
NeOZeN
September 15, 2013, 11:02am
2
200R - Serious Expansion and Cooling Capacity
Seven PCI-E slots with thumbscrews and room for cards up to 430mm long (300mm with drive cage) CPU coolers up to 160mm in height Install up to four hard drives and four SSDs at once Up to eight fan mounts (depending on hard drive configuration)
HAVIK-140 - Cooler Dimensions 140 (W) x 166 (H) x 120 (D) mm
It won't fit. Are you planning on modding the case to give it a window?
No, but I like things to have a uniform colour code, I don't know why lol
NeOZeN
September 15, 2013, 11:26am
4
Even when you can't see it? (Don't worry I used to be the same :P)
NeOZeN
September 15, 2013, 11:34am
5
Black, 159mm --> http://pcpartpicker.com/part/xigmatek-cpu-cooler-darkknightiisd1283nighthawkedition
Thanks will probably use that, just out of curiosity what cases fit the Havik 140 in the 200R price range?
NeOZeN
September 15, 2013, 12:49pm
7
http://pcpartpicker.com/part/bitfenix-case-survivor
http://pcpartpicker.com/part/antec-case-threehundredtwo
Those are two that I've found so far. Just use that site and look through the cases at your price point. Then check the manufactures site to get the Max CPU Dimensions. It has to be at or greater than 166mm.
