I am buying a new PSU for my ITX build tomorrow, and I was wondering how good of quality the NZXT Hale Series is (this one in specific http://pcpartpicker.com/part/nzxt-power-supply-v2550w).
I am comparing it to these -
http://pcpartpicker.com/part/corsair-power-supply-rm550
Was going to go for a SeaSonic, but they are fucking expensive ):
NZXT Hale are pretty good. Though, I would choose the more efficient RM model at that price point.
The RM seems to be of an odd shape, it should fit into my Bitfenix Prodigy right?
It will fit the prodigy. The backplate of the prodigy is removeable, and it should fit any ATX sized PSU. However, Bitfenix suggest using a non-modular power supply in that particular chassis. It's easier to squeeze in without the modular connections.
http://pcpartpicker.com/part/seasonic-power-supply-s12g550
It's modular, and Seasonic for a similar price. Though, I advised against modular in the Prodigy, you can get a Seasonic unit for the price of the RM.
Well the thing is that I am doing a custom loop and stuff in this build, and I wanted sleeved cables. Sorry for the slow reply, I was at school.
I'm not afraid of doing some mods to the case.
