Besides the price difference what is the better case. What are some of the major differences. I really like the look of both and love the stealth cover in the H440. I just want to know what are the major differences and which one is the better case.
The H440 has support for a lot of radiators, fan hub, LED lit rear I/O, and plenty of hard drive spots. The Corsair case is just like any other except for the ssd mounts behind the hard drive cages
I really really like the H440. Properly love this case. Visually in my taste it is much better looking then the 750D.
The corsair have more hdd capacity and a bit better airflow.
The H440 have nice cover for the hdd bays and psu area. There is better cable management in the NZXT, showoff SSD mounts on the bottom of the case, that is the top of the psu area. OC3D YouTube channel have a really nice review of the H440.
If it was a bit cheaper I would have considered it for my build, but it's a bit to expensive for me. Also a HUGE plus is the white color.
I love the white color too. I feel both have good cable management. The cover is a great feature that blocks the rats nest of wires that is inevitable for a noob system builder like me. The air flow was a concern of mine with the H440. Im not worried about the hdd space. Im only going to be using a 2tb hdd and a 256gb ssd and plan to build a nas in the future. The rear lit I/O is a huge plus. I've decided to go to go with the H440. Im planning to build it at the end of June.
I wouldn't worry overly much about the airflow. It's got large enough ventilation ports, so you'll be fine.
Ok that was my biggest concern good to know not to worry.
