NZXT H440 Potential Recolour
So like many here I saw the H440 form NZXT and fell in love. I love the White but I have a long time issue with cases and choices of colour. This stems back a while to the BitFenix Prodigy cases. First black, then white, soon after red and orange finally blue and green. No yellow. In fact I have only ever seen one factory yellow case it is was an anniversary commodore 64 PC.
With this in mind I have some time off coming up and I was wondering. How hard would it be to completely dis-assembly the H440 down to parts and spray the white parts yellow while leaving the black vents and accents black.
The end result would be a stunning yellow and black case. This is not to every bodies taste, that is fine. Can it be done?
People who have the case, does it look friendly to the prospect of dis-assembly or is it all spot welds and rivets. Wendell had a good poke round in his video and it looked pretty doable.
Or am I just mad and on track to destroy a case? I don't have it yet I am planning right now.
masking tape. i dont think it would be hard, just time consuming because to do it right you need to take your time and move methodically. just mask the areas you want to keep black and do light coats(to prevent running) of yellow untill you are satisfied.
If it's built like the NZXT Apollo and Vulcan, most of the plastic parts should simply be attached with screws.
Sounds good so far. Definitely be looking into it further in the coming months.
