Hello all
I’m on with a build for someone at the moment. 90% of the parts are new from my local component shop which is reputable and I have no issues with and 2 parts (cpu gpu) are used items. I’m having an issue either with a bad m/b or m.2 drives but im scared to sacrifice a known good drive that’s in use to test if the m/b fries it.
The components are as follolws
Gigabyte b450m d3sh
Ryzen 1700x
2x 8gb gigabyte ram 2666
ocz 500gb ssd
gtx1070
transcend 128gb m.2 nvme
600w bronze psu
p300 case
240 AIO
So all the parts arrive and I build the rig. Please find attached pictures.
When i go through the bios everything shows up fine, I restart the pc and once it gets cycled I power it down, add in my windows install usb which is 1903 build and a new download,
I power on and it starts the install. when I hit the install location I choose the nvme drive and the install starts. it gets to 34% and freezes. the mouse moves but the pc is not making progress and then it spits out the error code in the pictures 0x80070001 I think it is.
The pc will not then see the nvme drive. I check the bios, no drive showing at all.
the bios revision was f3 but it should be fine I thought as it was a 1st gen cpu.
I then download all the bios revisions for the board and install them in sequence so my bios is now f42b but the drive still doesn’t show.
I popped in a 240 sata ssd to test the system. same usb stick etc and it all checks out and runs great. so I open my main pc and remove the nvme from it and place in this transcend one. it doesn’t show up on my known good pc. Like wise I pop my Samsung m.2 into the new build, check the bios and it shows up. I didn’t try installing to it because the drive is in use and I don’t want to risk losing whats on it.
So today after work I go up to the shop, they check and replace the drive, never saying what they found. Like for like same drive exchange.
Get home, mount it, check it showing up in the bios. power down, remove my stand in sata drive and boot from the usb installer. Exact same thing happens. 34% fails and spits out the error code,
I’m now wondering if its the board or if its the nvme drive as ive had 2 of the same drive do the same thing.
Any thoughts on what I can do to figure it out?
Obviously the drive has to be replaced again so im thinking pack the wholr rig and a kbm when I go and install windows there but im not sure they will allow that.
