Nvlddmkm stopped - 4101 error
Hello everyone, recently I’ve been having some GPU driver crashes in World of Tanks. I thought they were due to my undervolting, but I was wrong. Resetting everything didn’t fix the issue (that weirdly appeared when I started tinkering with undervolting) and going into the event viewer I discovered that the nvlddmkm driver is stopped and correctly restarted by the system.
I can’t figure out for the life of my why this is happening. I did 4 passes of memtest86 a while ago and they reported no errors so I think my system is stable, but there must be something software related.
Do you have any ideas on what the possible causes could be and how can I rule them out one by one? Thanks!
Problem solved: I had the suspiscion that something wasn’t right and I downloaded AIDA64. To my surprise the memory stress test crashes almost immediatly with an hardware failure error.
Turns out my RAM kit is a dud and can’t sustain 3600CL18 @1.35~ V. Even if it’s a Samsung B-die kit. I’m trying my luck with another one of those kits in hope that it won’t behave like this.
