I finally got Arch installed on my desktop (hooray) and I'm trying to get all the settings good to go. I'm not new to Arch, but I am new to having a constant multiple monitor setup and Nvidia drivers on it.
I got it to remember my main display, but that's about it. Here's the output of my current /etc/X11/xorg.conf file:
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings: version 352.21 ([email protected]) Tue Jun 9 22:42:41 PDT 2015
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0" 0 0
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
Option "Xinerama" "0"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
# HorizSync source: edid, VertRefresh source: edid
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Sony SDM-HS53"
HorizSync 28.0 - 52.0
VertRefresh 57.0 - 63.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "GeForce GTX 760"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "Stereo" "0"
Option "nvidiaXineramaInfoOrder" "DFP-3"
Option "metamodes" "DVI-I-0: nvidia-auto-select +0+0, HDMI-0: nvidia-auto-select +2944+284, DVI-D-0: 1920x1080_144 +1024+284"
Option "SLI" "Off"
Option "MultiGPU" "Off"
Option "BaseMosaic" "off"
SubSection "Display"
Depth 24
EndSubSection
EndSection
Any help would be appreciated. The layout should be that DVI-D is in the middle, HDMI is on the right, and DVI-I is on the left and slightly raised, but on every reboot the layout switches to DVI-I in between the other two with the top in-line.
Also, if it helps, DVI-I is 1024x768. I know the current setting is auto. If need be I can post screenshots tomorrow as well.
