Hello all!
Iv'e been trying to use shadowplay to record my gameplay, but for some reason it won't let me change the default save location (which is on my OS~SSD). I have tried everything i can think of, from reformatting my pc to re-installing my drivers and Geforce experience. I even rooted around in the program files to try and find a config. file that retained the save location. Please help! OBS works well enough but i want shadow play for usability and such! note that shadowplay works, it will record gameplay, but it saves it all on my ssd which doesn't have enough space (128gb) i want to record gameplay on an extra 500gb drive i have.
My system specs are bellow
Mother Board : gigabyte ga-990fxa-ud3
Ram : DDR3 16 gb Kingston hyperX limited 1600mhz
CPU : Amd FX-6200 3.8ghz
GPU : PNY GTX 770 XLR8 (2GB)
Hard Drives : lots
OS : Windows 7 Ultimate 64bit
