Nvidia-settings seg fault
If I run 'sudo nvidia-settings' it refuses to launch all it does is quit and go to the next line I've tried uninstalling purging I found out that I didn't have an xorg.conf file so I created one (used the nvidia tool) and the settings still won't launch I've tried different drivers it still won't launch
I'm running linux mint 17.3 kernel 3.19
my ultimate goal is to disable vsync so that l4d2 stops crashing any advice would be helpful
thx
kat
