I Have this old pc that when I start up windows XP is has this NTLDR is missing message. I looked inside it and the cables are all connected right. help plz
a quick google revealed that this might also mean a damaged IDE cable, or a dying hard drive.
you might have also made the mistake of leaving a floppy in the pc when booting, if thats the case taking it out does the trick.
http://lmgtfy.com/?q=ntldr+is+missing+windows+xp
Chances are you'll need to reinstall the OS or repair it. Boot into Linux first from a live CD and check and see if the hard drive is OK. Then proceed to do repairs.
