Now gnome-control-center won't come up
So I recently updated my openSUSE machine and it broke both nautilus and gnome-control-center. In another thread we fixed nautilus by rolling it back to later version, but that didn't work for the gnome-control-center. Here is the output I am getting when I try to launch it from a terminal.
austin@RedRyzen:~> gnome-control-center
gnome-control-center: symbol lookup error: /usr/lib64/libwebkit2gtk-4.0.so.37: undefined symbol: gdk_wayland_display_get_type
A workaround that I have used for something similar sounding was to change my session to xorg gnome before login.
You may be able to fix it, but since one of your distro's packages isn't working with another this should get fixed, maybe update again if you have not, especially if on the rolling release.
