Not so known but awesome Gnome extensions?
Post in some not so known but really good Gnome extensions that you use?
Not a gnome extension, but an amazing thing I just found out about nautilus(gnome file manager).
You can run scripts on files just by right clicking the file and choosing a script.
You just have to move your script into the ~/.local/share/nautilus/scripts/
See here.
I started by writing a small script that plots the data from a csv file in a graph and displays it for 5 seconds. So I can just right click the file and plot the data.
I think the better question is, what kind of extension would you like to have?
Using AwesomeWM as your windows manager
kek
Well personally I use quite a few but a little known one that I often use is
Twitchlive-panel
