so built my first pc got all set up and no post... so checked all the line it all good Idk what to do.
the build is.
MOBO -M5A99FX PRO R2.0
CPU- AMD 8350
GPU- NIVIDIA GEFORCE GTX 760
RAM- 2x4 8GB CORSAIR VENGEANCE 1600
I have a 750 watt PSU so I know I am good there.
So any help at all plz I am about a grand into this build, and for all to happen is some led and fans to run I am loosing hope.
Thank You.
did you flip the switch at the back of the PSU?
are all the power cables to the mother board connected? 8pin CPU connected?
is your RAM fully seated?
is your POWER strip on?
has all the power to your GPU been connected? is your GPU fully seated?
Does your monitor work? is it on?
does your gpu work in any other computer?
does your motherboard smell like burnned bacon?
lol ya all of that is good I had a buddy with me. We checked and double checked everything and all we got is fans spinning and led from the mobo
only thing you can do now is try to isolate whatever the non functioning part may be by trying them in other machines that are known to work.
curious, what model is your PSU?
that's not a bad PSU, I use it myself, although it's possible you got a bad one...
