Hello,
I'm going to buy a fresh, new and kind of "awsome" PC. My Parts:
24" (60,96cm) BenQ GL Serie GL2460 schwarz 1920x1080 1xVGA/1xDVI € 115,32
Gigabyte Force K7 Stealth Gaming Keyboard USB Deutsch schwarz € 32,70
Intel Core i5 4570 4x 3.20GHz So.1150 BOX € 161,95
8GB Crucial Ballistix Sport DDR3 1600 DIMM CL9 Dual Kit € 55,90
ASRock H87M Pro4 Intel H87 So.1150 Dual Channel DDR3 mATX € 61,51
- 3072MB Gigabyte Radeon R9 280 Windforce 3x OC Aktiv PCIe 3.0 x16 € 189,00
400 Watt be quiet! Sy stem Power 7 Bulk Non-Modular 80+ Bronze € 38,41
Sharkoon VS3- S Midi Tower ohne Netzteil € 29,75
1000GB Seagate Desktop HDD ST1000DM003 64MB 3.5" (8.9cm) SATA 6Gb/s € 44,96
________________________________________________________
€ 729,50
I do need everything like mouse, monitor, HDMI cable and so forth. You get the idea... :)
My own thoughts and preferences:
- Gaming PC at first, maybe some photoshop occasionally.
- Maxed out settings in games, the higher the better. I'm a real graphic whore.
- No mayor upgrade the next 2 - 3 years possible.
- Maybe a bigger monitor, better GPU, CPU
- Budget is about € 850,00
- How important is the CPU in my case. Could I save some money and spend it in a better GPU instead?
- What about AMD CPU's? Is the performance of an Intel CPU within the same range sigificantly better?
- Do my thoughts have any relevance here or am I just fine this build? :)
