Noctua vs Cougar 120 and 140mm
I am thinking about making a new build and i was foundering is the Noctua pwm fans are better than the Cougar vortex pwm fans? The noctua ones are about $30 on newegg while the other ones are about $18, is it worth paying the extra $12?
only if you're using them on a heatsink or radiator. otherwise, the extra static pressure is irrelevant. I use a cougar on mine, works excellently
Noctua does make a better fan.  Price verses performance, Cougars are a good choice.
