Noctua NH-U12S with be quiet! Silent Wings 2 PWM ?!
Hey Guys,
Quick question, If I buy a Noctua NH-U12S and 2x be quiet! Silent Wings 2 PWM. can I just exchange the noctua fan for 2 be quiet! fans? (one on each side) Or would this be the stupidest thing you have ever heard?
 Links:
http://www.caseking.de/shop/catalog/CPU-Kuehler/Sockel-115X-Intel/Noctua/Noctua-NH-U12S-CPU-Kuehler-120mm::22590.html
http://www.caseking.de/shop/catalog/Luefter/Be-Quiet/be-quiet-Luefter-Silent-Wings-2-PWM-120mm::21695.html
Greetings ;) Lighto
While the noctua fans are great if you like the looks of the be quiet fans then use them. They have a lower db.
May i ask why you did not just go with the Dark Rock? I could not easily get that in the USA or it would be in my rig.
I don't know why I would not use the dark rock... but I've build 5 rigs with Noctuas inside and and whenever I see CPU cooler tests the noctua coolers are the best. I'll think about the dark rock a bit ;)
I am not tying to persuade you to change from the noctua. I just really like the look of the rock.
