I recently picked a silverstone RL06 GP (3x intake fans, 1x exhaust and I plan on adding 1 top exhaust fan). It appears I’m limited to 158mm cooler height i’m trying to decide between Noctua NH-U12A ($130 CAD ) vs NH-C14s ($95 CAD).
This will be cooling a ryzen 3000 or the upcoming ryzen 4000 (12c/24t to 16c/32t undecided).
The reviews I’ve read seem to give the C14s a slight edge for CPU/VRM cooling but will the downfiring airflow disrupt the GPU cooling performance? Would the use of SP fans on the exhaust/top help if this is an issue? Am i better off going with the NH-U12A?
I have the NH-C14S in a mini ITX build and can tame the 3900x . But my case cannot take a cooler taller than 148mm . If you can fit it (and afford it) go for the NH-U12A - it’s even better (better even than many AIOs) …
Hello, welcome, run while you can…
Just kidding, walk normally. If you run you may trip and hurt yourself…
Try and find U12S… It’s pretty much the same cooler as the U12A just with different fans.
I’m not 100% sure but you may be able to stuff an NH-D14 in there. The cooler is pretty much the height of 120mm cooler with 140mm fan, so there’s that.
