Noctua nh-d15 vs corsair h110i gt
Hi guys i am new to this forum,
would you go for noctua nh-d15 Or corsair h110i gt
i'm not sure what to put in my new build
I know it doesn't list the GT version of the H110i, assume it will be rather close. Either way, they're about the same.
It's depends on preference really. if you wish to have a water-cooled setup, the Corsair H110i GT would be great especially cause it looks all nice and pretty. but if you don't want to deal with water cooling, the Noctua NH-D15 would be just as fine. as shown in the graphs above. personally i would go with the Noctua, simply because it's cheaper. and it's a quieter. but if aesthetics is more of your thing the H110i GT would be the better choice. BUT take into consideration that you have a place to mount the radiator cause it is pretty big.
Thankyou that graph helped this is my first build and my bulid is as followed
CPU - i7 4790K
Mob - Asus Z97 Pro Gamer
Ram - Corsair Dominator Platinum 16GB
Gpu - GTX 980
Psu - Corsair RM 850
Case Phanteks Enthoo Pro White
Storage - 1TB + SSD
Would you change anything?
In my opinion, No. lol that's an excellent build. since you are spending a lot maybe hook up the case with some fans.
I was going to buy 4 Noctua NF-P14S and place them round my case.
i will post pic's when the build is complete thank you for your advice :)
