Hey guys
A few days ago my new mouse arrived (Func ms-3) and I had several driver problems between the mouse and windows 8, and so after several fix methods I finally found one that worked. However during this time I had updated by updating the bios for my motherboard (Asus M5A78L-M/USB3 AMD Socket AM3+) to the latest recommend build published by amd, using the amd rom flash utility.
This was fine until today I attempted to take my computer out of hibernation and I failed to get a systems beep! I also failed to get any output from the computer apart from the fans that are attached directly to the psu started spinning. After leaving the computer for about 10 mins I pressed the reset button, and nothing happened, and so I pressed the off button... and nothing happened, so I hard turned the computer off and then restarted it. Again nothing happened.
I have considered that it may have something to do with the mobo battery, however it is a very young system (about a year) and so I expect it may have something to do with the bios update, any help would be rewarded with a nice cup of tea
