No signal
This weekend i bumped to the site of my running computer with a broom, it frooze and since then im not able to get any signal to any screen.
  • tried different screens, cables and ports on the GPU
  • removed and reinstalled GPU
  • tried the integrated and got no signal either
  • computer powers up normally
Any suggestions? As i have no signal at all i dont think its related to the internal hard drive, RAM or anything else, but I might be wrong
I am a little confused. Are you saying you saying you hit your computer with a broom while sweeping?
I would start by pulling the GPU and setting it aside. (Sounds like you did this) Next plug your monitor into the integrated output. I would test the monitor and cable if you can with a different output. If you get a display then you know you have a problem with the GPU. If it doesn’t display you can continue troubleshooting.
Hit the side* with a broom.
Ill test it again, but didnt get a signal on the integrated channel either when i took out the GPU…
check the PSU power cable and all the motherboard power connectors make sure they’re tight. RAM too. Then reseat the CPU and re-do the thermal paste (good to do anyways)
Another good way to check if the computer starts is to power it on, wait for it to start up and try CapsLock (or NumLock, or ScrollLock) to see if it toggles the LED on your keyboard.
If it does, you (probably) have some sort of video problem, if it doesn’t then your computer is not starting normally.
I would pull the GPU for now, re-seat all RAM sticks, power cables, and even the CPU if all else fails. Side wack could have bumped them out of place.
