No Signal to Monitor
Hi guys,
I'm trying to connect my monitor up using a DVI cable. From my knowledge both my monitor and tower are DVI-I dual link ports whilst the cable I have is a DVI-D single link.
Will this still work? I have tried using it in both the DVI ports in the back of my tower however no luck in picking up a signal.
Thanks for any help you can give me in advance.
Yeah well if it doesnt work i recomend you to buy a new cable, i mean it´s not that expensive.
Yeah I know, I was just curious as to if it should be working and perhaps I have broken it, or whether it wasn't compatible to begin with.
