Well I just built a APU based system and I have another problem :/ There is no post screen, which is kind of weird because all the fans are spinning. I plug in my VGA monitor (Yes it's the only monitor I have for now) and power it on. Nothing. Am I just not waiting long enough? I thought something would pop up after like 3 minutes.
Help?
My build: http://pcpartpicker.com/user/ViolentBoo/saved/1OAC
How can I hear the beep? I have the speaker but where do I install it?
Look in your motherboard manual for the front panel connectors. There should be one labled "SPEAKER". Plug it into that.
Does your monitor work? Have you tried using that same monitor and exact cable (may be broken somewhere) with a different computer? Does your computer post beep now since you installed your speaker?
Start with the monitor. I recently built my friend a rig and we missed the post screen because it wasn't hooked up. we then plugged it in and it was waiting for use to put something on the drive.
Make sure ALL of te front panel connectors are in correctly Consult the manual. Everyone does it. You're not less of a man for checking.
If that still doesn't work try booting with only one stick of ram, switch them out to test each one. In your case you only have 1 stick. If you have another stick of ddr3 in another machine try using of them to test it.
Sorry for not responding for a while. :/ Hugs?
Alright there are a few more things that you guys mught want to know that I've done so far:
1. I plugged in the speaker and there was no beep. Does that mean that there is a connection that I've done wrong?
2. The monitor works fine. My laptop screen is broken and I use a secondary monitor so I can actally use it.
3. I switched the place of the ram to the other dim to see if that did anything. It didn't.
4. I disconnected and reconnected the front ports and it still worked but still no post screen.
So did I do something wrong? I already had a bunch of problems on the way here so I want this fixed! :D
Alright so I tried pluging in an HDMI cable into the TV that I had and still nothing. One of the attemps of me booting the PC, had a beep. Progress?
Look in your motherboard's manual and find the section about beep codes. Look up the amount of beeps you heard, and that should correspond to an error.
