- Budget. How much are you willing to spend? 1500
- Where do you live (what country), and what currency do you use? USA
- -Is there a retailer you prefer? Not really
- Do you need or already have peripherals? (this can add to costs) Already have
- What will you be using your future computer for? Gaming? Rendering? Mix of both? Or is this a home media PC? Gaming, everyday use and possible Rendering in the Future
- Do you overclock or want to get into overclocking? Possible, never looked into it
- Do you plan on going for custom watercooling now, or in the future? Probably not
- OS. Do you need a new one? Yes
- Do you plan on Mining BTC either for yourself or Tek Syndicate? I have no idea what this means
If you Game-
- What kind of settings do you like? Like to be able to play on ultra
- What resolution will you be playing at? //or would like to play at 1920x1080
- What kind of games do you like to play? Fps, mmos
- What specific game will you be playing (if applicable) Battlefield 3, Arma 2+3, Mount and Blade
So I have been looking on youtube on how to build computer but it doesn't really tell you on how to choose your hardware. I am lost, I have no idea if things are compatable with each other, if it is a good peice of hardware. I also don't understand all the different types of graphics cards, motherboards, etc.. If anyone could help me come up with a computer build I would be thankful
