So, a new CPU range is released and no one kind cared to release any motherboards for the IVY-E but Asus with the X79Deluxe that really benefits from the new stuff added to IVY-E and also Asus will be releasing the Formula black, But don't you guys think that IVY-E was let down with that careless attitude of Motherboard makers? because I am sure that we can all benefit from a New Big Bang from MSI or a New Assassin from Gigabyte, a New Extreme from ASRock?
I wonder what are they thinking, because a ton of people have been waiting for IVY and no one really cared to accommodate it?
Any thoughts or news?
But connectivity is better on Ivy? like more SATA6, and PCI-E 3, that would make a difference you know, even if marginal
Sata is taken care of through the chipset and the chipset hasn't been changed.
The x79 chipset allows for PCI-e 3.0 already even though SandyBridge-E didn't utilise it.
The only other change I can see, is the change in the memory controller to allow 1866Mhz Memory without OCing. But seeing as the memory controller is on the CPU, it doesn't require a board change.
Basically it has been made so you only require the new chip to upgrade.
People in general are not that excited about Ivy-E. It's the same old same old.
It's the exact same change going from a Sandy chip to an Ivy chip, you just have PCIe 3.0, native USB 3.0, and a few new boards.
Well, it's not so much careless as much as it was that they all already had motherboards that already support it. All they needed to do was release a BIOS update and they can save themselves a lot of money in R&D.
As for the chip itself, it was released way too late giving features that are already present on consumer grade chips(With the exception of PCI-e bandwidth). Haswell-E should offer enough new features to be worth looking at, failing that Broadwell is set yo be a big release
