Nixnote2 - nothing provides libhunspell-1.4.so.0()
Hi everybody,
I am running Fedora on a dell latitude E6420. I recently upgraded Fedora from version 25 to 26.
Now I have a bit of a problem with installing Nixnote2 again. I followed the instructions on Github.
But now I am getting
- nothing provides libhunspell-1.4.so.0()(64bit) needed by nixnote2-2.0_beta10-3.ndias.fc26.x86_64
A quick dnf whatprovides "libhunspell*" returns that there are some libhunspell options available:
hunspell-1.5.4-2.fc26.x86_64 : A spell checker and morphological analyzer library
Repo        : @System
hunspell-1.5.4-2.fc26.i686 : A spell checker and morphological analyzer library
Repo        : fedora
Repo        : fedora
Anybody got an idea on how to fix this?
BTW: I am not sure if this would count as a small issue, so that I should have put it into The small linux problem thread. Are there any guidelines as to what should go into The small linux problem thread?
Install 1.5 manually. Force install nixnote and create a symlink for 1.4 if needed. yum $yourflags --force path/to/package
