PS G:\servers\nginx-swag> docker ps -a
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
6a4d7d1874ac linuxserver/swag “/init” 18 seconds ago Created reverseproxy
8db24f2acab2 nginx:latest “nginx -g 'daemon of…” 2 months ago Exited (0) 4 hours ago abyssnginx
PS G:\servers\nginx-swag> docker-compose up -d
Creating reverseproxy … error
ERROR: for reverseproxy Cannot start service reverseproxy: Ports are not available: listen tcp 0.0.0.0:443: bind: An attempt was made to access a socket in a way forbidden by its access permissions.
443 is still bound by the system. But having it on 9090 and then just declare 443 to be 9090 in router worked. I was able to open abyss.fi in https. But now I want to open Nextcloud in https with address cc.abyss.fi
Try to add something these to the configuration file /path/to/config/nginx/site-confs/default
server_name cc.abyss.fi;
location / {
proxy_pass http://<your_nextcloud_container_name>:<port>;
proxy_http_version 1.1;
proxy_set_header Upgraded $http_upgrade;
proxy_set_header Connection keep-alive;
proxy_set_header Host $host;
proxy_cache_bypass $http_upgrade;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header X-Forwarded-Proto $scheme;
proxy_buffers 64 4k;
proxy_buffer_size 4k;
client_max_body_size 10G; # probably you want to transfer large files with your nextcloud
Just put it into the block that sais default_server, listen 443. Remove the current location /. If you need more sites for instance probably your default_server should be abyss.fi or www.abyss.fi. You add more blocks very similar to the one that you will have then. Just remove the default_server part and add a different server_name.
Also as said earlier you need to add the this container as trusted_proxy for your nextcloud instance.
## Version 2021/04/27 - Changelog: https://github.com/linuxserver/docker-swag/commits/master/root/defaults/default
error_page 502 /502.html;
# redirect all traffic to https
server {
listen 80 default_server;
listen [::]:80 default_server;
server_name _;
return 301 https://$host$request_uri;
# main server block
server {
listen 443 ssl http2 default_server;
listen [::]:443 ssl http2 default_server;
root /config/www;
index index.html index.htm index.php;
server_name _;
# enable subfolder method reverse proxy confs
include /config/nginx/proxy-confs/*.subfolder.conf;
# all ssl related config moved to ssl.conf
include /config/nginx/ssl.conf;
# enable for ldap auth
#include /config/nginx/ldap.conf;
# enable for Authelia
#include /config/nginx/authelia-server.conf;
# enable for geo blocking
# See /config/nginx/geoip2.conf for more information.
#if ($allowed_country = no) {
#return 444;
client_max_body_size 0;
location / {
# enable the next two lines for http auth
#auth_basic "Restricted";
#auth_basic_user_file /config/nginx/.htpasswd;
# enable the next two lines for ldap auth
#auth_request /auth;
#error_page 401 =200 /ldaplogin;
#include /config/nginx/authelia-location.conf;
try_files $uri $uri/ /index.html /index.php?$args =404;
location ~ \.php$ {
fastcgi_split_path_info ^(.+\.php)(/.+)$;
fastcgi_pass 127.0.0.1:9000;
fastcgi_index index.php;
include /etc/nginx/fastcgi_params;
# sample reverse proxy config for password protected couchpotato running at IP 192.168.1.50 port 5050 with base url "cp"
# notice this is within the same server block as the base
# don't forget to generate the .htpasswd file as described on docker hub
# location ^~ /cp {
# auth_basic "Restricted";
# auth_basic_user_file /config/nginx/.htpasswd;
# include /config/nginx/proxy.conf;
# proxy_pass http://192.168.1.50:5050/cp;
# sample reverse proxy config without url base, but as a subdomain "cp", ip and port same as above
# notice this is a new server block, you need a new server block for each subdomain
#server {
# listen 443 ssl http2;
# listen [::]:443 ssl http2;
# root /config/www;
# index index.html index.htm index.php;
# server_name cp.*;
# include /config/nginx/ssl.conf;
# client_max_body_size 0;
# location / {
# proxy_pass http://192.168.1.50:5050;
# sample reverse proxy config for "heimdall" via subdomain, with ldap authentication
# ldap-auth container has to be running and the /config/nginx/ldap.conf file should be filled with ldap info
#server {
# root /config/www;
# server_name heimdall.*;
# include /config/nginx/ldap.conf;
# location / {
# # the next two lines will enable ldap auth along with the included ldap.conf in the server block
# auth_request /auth;
# error_page 401 =200 /ldaplogin;
# resolver 127.0.0.11 valid=30s;
# set $upstream_app heimdall;
# set $upstream_port 443;
# set $upstream_proto https;
# proxy_pass $upstream_proto://$upstream_app:$upstream_port;
# sample reverse proxy config for "heimdall" via subdomain, with Authelia
# Authelia container has to be running in the same user defined bridge network, with container name "authelia", and with 'path: "authelia"' set in its configuration.yml
#server {
# root /config/www;
# include /config/nginx/authelia-server.conf;
# location / {
# # the next line will enable Authelia along with the included authelia-server.conf in the server block
# include /config/nginx/authelia-location.conf;
# enable subdomain method reverse proxy confs
include /config/nginx/proxy-confs/*.subdomain.conf;
# enable proxy cache for auth
location / {
proxy_cache_path cache/ keys_zone=auth_cache:10m;
# main server block
server {
root /config/www;
#return 444;
location / {
location ~ \.php$ {
# location ^~ /cp {
You need to duplicate the 443 server block for every website i.e. default_server in the end should probably be the website and another block that is not default server with server_name cc.abyss.fi. But try one thing at a time I guess.
The default_server part is where it goes when you don’t have anything for a specific name so it would now default to your nextcloud. Other blocks should mostly look similar except without the default server and different names. Might need slightly different configs based on what service you are proxying to.
Haven’t tested yet, but this would be the default file:
server {
server_name _;
# main server block
server {
root /config/www;
server_name _;
#return 444;
location / {
location ~ \.php$ {
# location ^~ /cp {
server {
root /config/www;
server_name cc;
location / {
proxy_pass http://nextcloud:90;
location ~ \.php$ {
#server {
# root /config/www;
# server_name cp.*;
# location / {
#server {
# root /config/www;
# location / {
#server {
# root /config/www;
# location / {
Your nextcloud and swag need to be in the same docker-compose.yml for this to work.
You can ofc manually assign docker networks, but docker-compose just does it automatically for services defined in the same file.
By the looks of the screenshot “nextcloud” isnt actually the container name but “nextcloud_app_1”, but I don’t see the swag container.
When you do it with one compose file the swag container should be in the same dropdown with all the rest. You should give the “app” service in your nextcloud compose file a container_name (so it is consistent and not some generated anything, which is the url you can use) and put the service from the swag yml into there too.
