Nginx not working
@PhaseLockedLoop
I use nginx as a reverse proxy for my lab. My issue is stuff works when connecting to the linode domain name on my device. But often it does not work for others. Like I load photos.mysite.com and it comes up for me as immich, but for other people it comes up as jellyfin or nextcloud. Any idea how to get it to load correctly for them?
Here is my jellyfin config
jellyfin nginx config
server {
        listen 80;
        listen [::]:80;
        server_name tv.mysite.com;
    # Uncomment to redirect HTTP to HTTPS
        return 301 https://tv.mysite.com;
server {
        listen 443 ssl;
        listen [::]:443 ssl;
        ## The default `client_max_body_size` is 1M, this might not be enough for some posters, etc.
        client_max_body_size 20M;
        # use a variable to store the upstream proxy
        # in this example we are using a hostname which is resolved via DNS
        # (if you aren't using DNS remove the resolver line and change the variable to point to an IP address e.g `set $jellyfin 127.0.0.1`)
        set $jellyfin 10.8.0.2;
#       ssl_certificate /etc/letsencrypt/live/mysite.com/fullchainsecto.pem;
#       ssl_certificate_key /etc/letsencrypt/live/mysite.com/privkeysecto.pem;
        #include /etc/letsencrypt/options-ssl-nginx.conf;
        #ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem;
        add_header Strict-Transport-Security "max-age=31536000" always;
        #ssl_trusted_certificate /etc/letsencrypt/live/DOMAIN_NAME/chain.pem;
#       ssl_stapling on;
#       ssl_stapling_verify on;
        # Security / XSS Mitigation Headers
        # NOTE: X-Frame-Options may cause issues with the webOS app
        add_header X-Frame-Options "SAMEORIGIN";
        add_header X-XSS-Protection "0"; # Do NOT enable. This is obsolete/dangerous
        add_header X-Content-Type-Options "nosniff";
        # COOP/COEP. Disable if you use external plugins/images/assets
        add_header Cross-Origin-Opener-Policy "same-origin" always;
        add_header Cross-Origin-Embedder-Policy "require-corp" always;
        add_header Cross-Origin-Resource-Policy "same-origin" always;
        # Permissions policy. May cause issues on some clients
        add_header Permissions-Policy "accelerometer=(), ambient-light-sensor=(), battery=(), bluetooth=(), camera=(), clipboard-read=(), display-capture=(), document-domain=(), encrypted-media=(), gamepad=(), geolocation=(), gyroscope=(), hid=(), idle-detection=(), interest-cohort=(), keyboard-map=(), local-fonts=(), magnetometer=(), microphone=(), payment=(), publickey-credentials-get=(), serial=(), sync-xhr=(), usb=(), xr-spatial-tracking=()" always;
        # Tell browsers to use per-origin process isolation
        add_header Origin-Agent-Cluster "?1" always;
        # Content Security Policy
        # See: https://developer.mozilla.org/en-US/docs/Web/HTTP/CSP
        # Enforces https content and restricts JS/CSS to origin
        # External Javascript (such as cast_sender.js for Chromecast) must be whitelisted.
        # NOTE: The default CSP headers may cause issues with the webOS app
        add_header Content-Security-Policy "default-src https: data: blob: http://image.tmdb.org; style-src 'self' 'unsafe-inline'; script-src 'self' 'unsafe-inline' https://www.gstatic.com/cv/js/sender/v1/cast_sender.js https://www.gstatic.com/eureka/clank/95/cast_sender.js https://www.gstatic.com/eureka/clank/96/cast_sender.js https://www.gstatic.com/eureka/clank/97/cast_sender.js https://www.youtube.com blob:; worker-src 'self' blob:; connect-src 'self'; object-src 'none'; frame-ancestors 'self'";
        location = / {
                #return 302 http://$host/web/;
                return 302 https://$host/web/;
        location / {
                # Proxy main Jellyfin traffic
                proxy_pass http://$jellyfin:8096;
                proxy_set_header Host $host;
                proxy_set_header X-Real-IP $remote_addr;
                proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
                proxy_set_header X-Forwarded-Proto $scheme;
                proxy_set_header X-Forwarded-Protocol $scheme;
                proxy_set_header X-Forwarded-Host $http_host;
                # Disable buffering when the nginx proxy gets very resource heavy upon streaming
                proxy_buffering off;
        # location block for /web - This is purely for aesthetics so /web/#!/ works instead of having to go to /web/index.html/#!/
        location = /web/ {
                proxy_pass http://$jellyfin:8096/web/index.html;
        location /socket {
                # Proxy Jellyfin Websockets traffic
                proxy_http_version 1.1;
                proxy_set_header Upgrade $http_upgrade;
                proxy_set_header Connection "upgrade";
immich config
server {
        listen 80;
        listen [::]:80;            # comment to disable IPv6
        server_name photos.mysite.com;
        return 301 https://photos.mysite.com;
server {
        listen 443 ssl http2;
        set $photoprism 100.119.56.77;
    location / {
        proxy_pass http://10.69.69.41:30041;
        proxy_set_header   X-Forwarded-For $remote_addr;
        proxy_set_header   Host $http_host;
        ssl_session_timeout 1d;
        ssl_session_cache shared:MozSSL:10m; # about 40000 sessions
        ssl_session_tickets off;
 #       ssl_protocols TLSv1.2 TLSv1.3;
 #       ssl_ciphers ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:DHE-RSA-CHACHA20-POLY1305;
 #       ssl_prefer_server_ciphers on;
        # Optional settings:
        # OCSP stapling
#        ssl_stapling on;
Why is photos config not redirecting the person to my immich instance but it does me?
I cannot really test it because it loads for me and I am not able to reproduce the redirect error on my end.
I think adding the bellow fixed it.
Ill give you steps you should take to debug but until tomorrow i must focus on my terahertz rf systems exam studying
Sure! Here’s the TL;DR:
First ensure each subdomain has its own server block in Nginx, and each block uses the correct server_name (e.g., photos.mysite.com)
Secondly verify that all subdomains (photos.mysite.com, etc.) point to the correct IP in your DNS settings.
Third… Add a default_server block to catch unspecified subdomains and prevent mismatches. For example, redirect to an error page or return 444.
Fourth idea here is to ask users to clear their browser and DNS cache (ipconfig /flushdns or equivalent).
On your end id also run sudo nginx -t to check for configuration errors and config dups, then restart with sudo systemctl reload nginx.
If thats still not working id review /var/log/nginx/access.log and /var/log/nginx/error.log to see where requests are being misrouted.
Good luck
