Newbie needing help (UK)
Hey, my pc just broke and ive decided to build a new one for the first time. Ive dug deep behind the sofa's cushions and old jean pockets and my student life style has left me with a horrendous ammount of small change. With this money ive put together a very budget build but being the idiot i am, I'm not even sure it'll work. I will post what i have and links to the place of purchase if needed.
CPU: http://www.amazon.co.uk/AMD-HDZ965FBGMBOX-Phenom-II-965/dp/B002SRQ214/ref=sr_1_1?ie=UTF8&qid=1354920197&sr=8-1
GPU: http://www.amazon.co.uk/Asus-Radeon-HD6750-GDDR5-Graphics/dp/B005G7QNEO/ref=sr_1_16?s=computers&ie=UTF8&qid=1354920272&sr=1-16
MOBO: http://www.novatech.co.uk/products/components/motherboards/amdam3plus760gchipset/ga-78lmt-s2p.html
PSU: http://www.novatech.co.uk/products/components/powersupplies/cp-9020046-uk.html
HDD: I have an old 7200 rpm HDD that i'll salvage, and i'll probably upgrade at a later date
CASE: http://www.novatech.co.uk/products/components/cases/cases/nov-vulca2.html
OD: Again i have an old one until i get one thatll play blu rays :)
RAM: http://www.novatech.co.uk/products/components/memory-pc/ddr3-pc3-12800/1600mhz/bls2cp4g3d1609ds1s00ceu.html
Am i forgetting something simple? Will that PSU be enough? Does that motherboard even support my ram/cpu/gpu?
Thankyou in advance :)
Any tips on posting maybe? i plan to start as i progress in knowledge
pcpartpicker, helps show if parts are compatible, estimates wattage and shows you best prices online. Also makes it easier to show your build to others. mobo link is broken
Cheers :) will certainly give it a look. Ye the mobo link didnt work so i just found another
thankyou for your feedback
What's your budget?
I assume your going to use it for gaming?
CPU, GPU and MOBO are compatible but the mobo doesn't support RAM that fast.    edit: i mean you could still use it but the motherboard can only go at 1333
Somewhat, nothing too tasking. Maximum would be CS:GO / WoW
Ah so i see, would this MOBO still have the correct slots for the GPU?
http://www.novatech.co.uk/products/components/motherboards/amdam3plus760gchipset/960gm-gs3fx.html
yup
Without an indication of what your willing to spend it's pretty hard to advise something. If you don't know how much to spend or you just want to spend the minimal amount of money. Then please tell me what your planning to do with your pc.
Thankyou, you've been alot of help
Light gaming but mainly web browsing and word proccesing
Also at the mo' i have around £300
[url=http://pcpartpicker.com/uk/p/rt9p]PCPartPicker part list[/url]
[b]CPU:[/b] [url=http://pcpartpicker.com/uk/part/amd-cpu-ad560kwohjbox]AMD A8-5600K 3.6GHz Quad-Core Processor[/url] (£77.02 @ Amazon UK)
[b]Motherboard:[/b] [url=http://pcpartpicker.com/uk/part/asrock-motherboard-fm2a75mdgs]ASRock FM2A75M-DGS Micro ATX FM2 Motherboard[/url] (£51.85 @ Amazon UK)
[b]Memory:[/b] [url=http://pcpartpicker.com/uk/part/kingston-memory-khx1866c9d3k24gx]Kingston HyperX 4GB (2 x 2GB) DDR3-1866 Memory[/url] (£22.86 @ CCL Computers)
[b]Storage:[/b] [url=http://pcpartpicker.com/uk/part/samsung-internal-hard-drive-mz7pc128bww]Samsung 830 Series 128GB 2.5" Solid State Disk[/url] (£77.99 @ Ebuyer)
[b]Case:[/b] [url=http://pcpartpicker.com/uk/part/fractal-design-case-fdcacore1000bl]Fractal Design Core 1000 MicroATX Mini Tower Case[/url] (£32.38 @ Scan.co.uk)
[b]Power Supply:[/b] [url=http://pcpartpicker.com/uk/part/xfx-power-supply-p1450sx2b9]XFX ProSeries 450W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply[/url] (£35.00 @ Ebuyer)
[b]Optical Drive:[/b] [url=http://pcpartpicker.com/uk/part/lg-optical-drive-gh24ns90]LG GH24NS90 DVD/CD Writer[/url] (£13.98 @ Novatech)
[b]Total:[/b] £311.08
Comments:
Remove the DVD drive obviously if your not going to use it to save some money.
Also if you need more harddrive space replace the ssd with a mechanical harddrive. I recommend this one:
Western Digital Blue SATA 6 Gb/s 500GB
http://pcpartpicker.com/uk/part/western-digital-internal-hard-drive-wd5000aakx
Since you are on a budget it was quite difficult to get you a decent machine that's capable to run most games at decent fps but maybe that's just because I'm spoiled with higher fps. It will be fine for CS:GO and WoW though.
If your into overclocking you can push this cpu to 4.3Ghz even with (crappy) stock cooling so that's pretty neat.
I hope this was all if you have questions/suggestions let me know.
