Hello, I am trying to set up a Minecraft server for me and my friends using the following mods:
-iChuns Portal gun
-iChuns Gravity Gun
-Lambdacraft
The server is a Forge Modloader 1.6.4 server, and I have a problem. There are 5 different portal gun types (I have the max players set to 5) and I need each player that joins to be given a different portal gun (otherwise one can change the other's portals). I have more than 5 friends that play, and they're not all tech-savvy, so I was trying to come up with an automated system to give out the portal guns based on the order of who joins when. For example:
Bob joins 1st, he gets portal gun type 1
Bill joins later, he gets the next type
Sam joins next, he gets the third type
But the guns should also stay in the players inventory after they respawn(along with a set of the lambdacraft weapons), and if they join in a different order later, the player might get a new gun. Just as long as every player has a different gun from the others.
This server will run Bukkit plugins (written in Java) and I know nothing of Java. Can anyone point me to a plugin I can use for this, or perhaps help me cobble together an unofficial solution?
Thanks
