I am building a new workstation and I need some advice on the components for the build.
I am an architectural/interior designer and do a lot of Ray-tracing (CPU-intensive) and post-processing but I would also like the computer to double over as a gaming rig. I just need a machine with as many cores as possible, as much RAM as possible, and a GPU which can handle the latest game titles at 1080p with all settings maxed out.
So far I'm looking at:
CPU(x2) Intel Xeon E5-2697 v3
motherboard Asus Z9PE-D8 WS
RAM Corsair Dominator Platinum (64GB) DDR3
GPU EVGA 6GB GeForce GTX Titan
system drive 480 GB kingston v300 SSD SATA6 Gb
Storage Any 4TB SATA-III HDD
I have no idea what case would be compatible with this setup and how much power will I need. If you have any other suggestions or corrections to my list please feel free to point it out.
I would stay away from those Kingston V300s, they've been known to swap the NAND out for cheaper/slower stuff. Grab a Samsung 850 Pro or an ADATA SP920 instead. Also, the reliability of the 4TB and higher drives is less than great. If you could RAID a couple of 2TB drives instead, that might be a better situation.
Here's a suggestion build, http://pcpartpicker.com/p/s84BFT
Really I'd argue for this application the Samsung 850 Pro would be your best option. Expensive yes. But one of the best SSDs available.
I'd also recommend against one large (4TB) drive. You are better off with several smaller (1-2TB) drives. Much more reliable and you could put them in RAID to get some redundancy and a speed boost.
If going 4TB, Go with a well rep brand like WD Blacks. 5 year warranty and keep a backup with say your old drives or something. Just be aware that they do have a higher failure rate because there are more platars inside compared to a standard drive. Also if the 850 Pro is too expencive, 840 pro was the king os speed and is still one of the best and the 840 evo is the king of longevity speed behind the 850 pro.
The 850 pro is the best of both the 840 pro and evo.
