New to PCs. Advice?
A friend, of a friend, of mine has a used:
Palit Nvidia GTX 560
4GB G.skill ripjaw DDR3 1600
AsRock H55 motherboard
His price is $135. Is this a good deal? I am new to PC gaming and could easily be taken advantage of at this point. I don't want to buy it, then realize I need to upgrade a month after owning it. I watch Razethew0rld on youtube and it seems like this would be an appropriate place to get advice. I am not an "enthusiast" but want to run on high or max settings.
My friend put together the rest of the build, considering my $450-550 budget, using the parts above and these are the other parts he recommended:
CORSAIR Builder Series CX500 500W Power Supply
NZXT Tempest 210 CA-TP210-01 Black Computer Case
Intel Core i3-540 3.06GHz LGA 1156 73W Dual-Core Desktop Processor
SAMSUNG DVD Burner SATA Model SH-224BB
Western Digital WD Blue 500GB 3.5" SATA 6.0Gb/s Internal Hard Drive -Bare Drive
ARCTIC Freezer 7 Pro Rev.2 with 92mm PWM Fan
My budget is ~ $450-550 for the system.
Detailed answer please? I am new to all this and WANT TO DITCH MY CONSOLE :)
The 560 and Ram alone would be around that price if not a little more.
I can't comment on motherboards as i am only myself getting my first build together but RAM is so cheap just go on amazon and buy 8GB 1600mhz and buy the card seperately at a slightly lower price. That card with updated drivers should be all you need as anymore and your CPU etc may bottleneck it.
Sir $135 for the GTX560 and 4gb of DDR3 1600(is it two 2gb sticks or one 4gb stick?) is quite a good deal! If you were to spend $135 on a graphics card(new generation card) alone now a days you would only be able to get something along the lines of a HD7770, here is how the GTX560 does agaisn't the 7770: http://www.anandtech.com/bench/Product/536?vs=543
Is your $450-550 budget with the $135 included or on top of the $135? Either way, that i3-540 directly completes with a 965BE in price and in performance. For $450 you can get more performance for your dollar then the i3-540 can deliver. The system you listed will work, but there are so much better options right now for your money then socket 1156. Please let us know if you are interested in other build options, we can recomend intel and AMD builds that work properly nice.
on overclock.net you can buy 1st genneration i3s, i5s and i7s uber cheap, the GPU an ram alone is worth 135
http://www.overclock.net/t/1340939/intel-i7-860-w-p55a-ud4p-and-8gb-ddr3-for-sale-170
How cheap do the i3's go for roughly on the OC forums? What about the Sandy i3's and i5's? Thank you for your response.
I don't really know I know a hell of a lot cheaper than newegg, probably around 50% retail, correct me if I'm wrong but you can OC 1st gen i3s by FSB OCing
Indeed a very good deal! The overclocking i honestly don't know how they go about it in the 1st gen, thank you for the forum link i'll have to look around and see if i can snatch a i5 for a good deal.
Yes, I am interested in other build options! What would you suggest for the budget? Please help, thanks
Build one: http://pcpartpicker.com/p/tIwx This is a direct competitor to the i3-540 stock for stock, it is also one of the cheapest builds. It is a 965BE with  a decent motherboard and a proper power supply and cpu cooler(for oc and silent operation). Here is a bench between both processors: http://www.anandtech.com/bench/Product/102?vs=143
Build two: http://pcpartpicker.com/p/tHyC This is a improvement over the i3-540 and the 965BE stock for stock, it is $30 more then the cheapest build. The rest of the system is the same as the build one. Here is a bench of the FX4300 vs the i3-540: http://www.anandtech.com/bench/Product/700?vs=143
Here is a bench of the 965BE vs the FX4300: http://www.anandtech.com/bench/Product/700?vs=102
The cheapest possible build though is the i3-540, since you already have the motherboard with the gpu purchase you save some money. http://pcpartpicker.com/p/tIAS At $238  the i3-540 is the best deal as it rivals the 965BE but you have the advatange of the cheaper  parts in hand. If you are looking for the best bang for your buck the i3-540 is it, even if it is considered a old socket/cpu. It will do well in gaming, and it is a great deal if your goals for your system in the future are not extremely high.
Also please check out pcpartpicker.com as it gives you prices from various vendors, and if you are buying online you can save quite a large sum of cash.
